Stage 6 – Intake Manifold Skunk2
The EG need to breathe better. The stock intake manifold just won’t cut it, especially since we’re force induced.
Step 1 – remove intake manifold
Step 2 Inspect and clean up any gaskets left behind
Step 3 – reverse order
Step 4 – Test drive
The replacement is a Skunk2 manifold that has all the usual stuff that you would expect:
  • Increased Plenum and Runner Size
  • Oversized Throttle Body Opening
  • Increased Plenum Volume
  • 8″ Tapered Runners For Maximum Torque and Power Increase
In the end it should be better than stock 😀
