Re: ARCA 2008 Whisell Race Weekend 2
OLYMPUS DIGITAL CAMERA
The drama of racing.
It’s bee frustrating getting the car to the level that it is track worthy. There is just so much to complete. I didn’t even finish my check list.
It’s a shame that venture with a friend didn’t work out. He was too naive and I think maybe ego got in the way as I post over 10 seconds faster than he does on the track.
Anyway, during a short period of time this was what was added on top of working 10+ hours at work and traveling:
Fire Suppression:
https://speedracer.ca/portal/civic/fire-supression/
Disabled Steering lock
https://speedracer.ca/portal/civic/steering-lock/
Battery Remount
https://speedracer.ca/portal/civic/battery/
Front Facial Shield
https://speedracer.ca/portal/civic/ed-209-effect/
Bolt Fix / exhaust leak
https://speedracer.ca/portal/civic/bolts-and-bits/
New Gasket Fix for turbo compressor exhaust
*Thanks Matt!!*
https://speedracer.ca/portal/civic/gaskets/
Gauges
https://speedracer.ca/portal/civic/stage-7-gauges-and-bling/
Motor Mounts (very sloppy when on the track until this was added)
https://speedracer.ca/portal/civic/whats-a-little-vibration-motor-mounts/
Coolant lines fixing
https://speedracer.ca/portal/civic/oil-pressure-and-coolant-temp-revisted/
Catch Can Remount
https://speedracer.ca/portal/civic/catch-can-revisited/
Getting tires re mounted and changed over
https://speedracer.ca/portal/civic/tires-and-more-tires/
** This was just gay having to do this twice and pretty much a waste of money.
On top of this life and everything in between. I do see other people being able to put out that much energy for racing and I am at awe because I don’t know where that comes from. I’m running on four hours of sleep everyday and I still can’t keep up.
The big drama with rushing to get the car ready as Friday night – last minute as is the case. I just finished cleaning the interior, re torqued all the bolts, and rechecked the ECU …
The civic fails to start. Stupid race car. The Hondata S200 (that’s what you get for a used unit – lots of funky quirks). The famous CEL comes on for data read connection error. It’s now 10 PM and nothing I can do. I call Ant and threw in the towel. But, he wouldn’t hear of it and neither would Gary as they were doing the same thing as I was – last minute preparations. So Ant called in a couple of friends at STRD (Speed Tech) and off I go in borrowing a spare ECU and a spare S200 late at night.
By the time the Civic is trailer up and parts in the TLC it is just 3 am. It doesn’t look like I will get my usual 4 hours of sleep as I need to be up at 6:15 am so that I am at the track at 7 am to steal good spots for pitting at the track.
Page 1     Page 3
