Stage 4 – Ball Joint Removal
Typically to remove a ball joint a special tool is required. It just makes life easy, but what about the days you can’t find the tool or can’t afford one…
So, with a bit of physic’s and a swift kick removal of the ball joint can be accomplished.
There are 2 options to this. You can use an extension or a wrench.
jack the car up so that you can position the tool in-between the ball joint – take note of the axel.
Then drop the jack so that’s snug and then kick
Voila
