Stage 2 – Camber
After many phone calls to countless manufacturers  – What? You want camber?!?
We decided to buy a camber correction kit and then modify it so that we can get camber.
We wanted adjustments from 0 to -2 degrees for camber. The product of course is designed for -2 to 0 degrees of camber. As it turns out the answer is no, w can not install the kit backwards.
We have looked at Omni, Skunk, and SPF, but it seems most folks are using it to correct camber. Anyway, maybe we don’t that much camber – technically you want more grip and camber will remove that.
